[Pro] How to make a responsive website?
I would like to stay in FW for my Responsive sites (still made in a easy -free-way) but it seems difficult to find the good written information (or tutorials) about it. Otherwise I will be obliged to find a solution with another software supplier. I searched the web but good info it’s very difficult to find. Softpress doesn’t even provide us with serious information about this very hot topic on their site. Thank you all for your help.
Have a look at Caleb’s Backdraft Template http://backdraft.onrampwebdesign.com/
Can you create a responsive website in Freeway?
Yep.
Can you create a responsive website in Freeway using drag-n-drop construction and without knowing how to write HTML and CSS?
Nope.
If you want to roll your own responsive website in Freeway, you will really need to learn HTML and CSS. Once you can hand-code a responsive website, rolling that knowledge into Freeway and build responsive websites is pretty easy.
On the other hand, if you are hard-set against learning how to hand-code, and can live with iWeb-like limitations, take a look at Sparkle: Sparkle: the best Mac website builder
