[Pro] How to properly add Freeway Actions
I’m experiencing problems with Freeway actions whereby I install them by double-clicking.
They then don’t show up in my list of actions from the menu, despite being present in what I take to be the correct folder: user > Library > Application Support > Freeway 5 > Actions
This has happened twice now to “Background Fade” (simply not there) and “Carousel” (only showing the “Carousel text tab” and none of the other elements to the action).
Any ideas, any help would be gratefully received… ?
I’m running FW Pro 5.5.2 on a Core i7 iMac
Well, Carousel and Carousel Pane will only appear in the list if you
currently have selected a layered HTML box. Carousel Button and
Carousel Tab will only appear in the list if you have selected a
graphics box. All Actions are contextual – they only appear when the
current selection matches their internal use-case.
And Background Fade is a Page action
So with nothing selected on your page Page>Page Actions>Background Fade
Aah, thanks Walt, I should have known that of course. But then I was also looking under the ‘Insert’ > ‘Action Item’… instead of ‘Item’ > ‘Actions’.
I now feel kinda foolish… but I shall know in future. And thanks again for some great actions!
