I can not get the code I get from Linklok to apply to the emals cart. I can not even apply the text to my page in freeway.
Your buy button must match your products in the linklokme.php file.
Select the your button hit command-k and select the external option and enter the code in the text area. Note the + between words in the product name.
Below is a sample of what your product description looks like in the linklokme.php file
$Products[] = "k201,A Jumping Dog - Download,C0=4.99,http://mrsagesstories.com/stories/A_Jumping_Dog.zip,0,4320";
To expand a bit on the things that are thee most important in the above code are the SCODE which in the above example is the k201. The description is important for the sale portion but doesn’t affect LinkLok in any way. The price is the C0= above and then the link to the product, whether or not another IP can download this item, and then the duration of the availability of the link itself.
Now if you use the FW action then it’s not going to be easier. It’s easier to just write out the links and if you use a CMS then it can be made even easier. I know my site auto-generates things for all my screencasts without me having to do anything but enter a description and an excerpt. The rest is automated.
Hopefully Marcels help solved the issue.
thanks i will give it a try
How do you apply the code from linklok to your website.
It’s in the manual.
You have to use the custom !!!variables!!! to make it work. So for instance you could write out:
<a href="!!!link!!!" title="!!!description!!!>Download This Sucka</a>
Then it’ll work.
I do not know how to put the code into my web page. Where do you put the code in the website
Click on Menu Item under the Insert option in your menu. Paste your code in the HTML markup box and click OK
I see two options. Either use an HTML Markup item which can be inserted from the Insert menu or my personal favorite which is ‘Crowbar’ and that’s found in the actionsforge.com.
To insert Crowbar you’d go to Insert > Action Item > Crowbar.
After I Copy the text and open the HTML mark up window It will not let me
paste the text into the window
found in the actionsforge.com.To insert Crowbar you’d go to Insert > Action Item > Crowbar.
Nate, you need to use a Markup Item instead of the HTML Markup. You do that from the Insert menu instead of the Page menu.
That still will not let me right click inside the window
Right click? Why right click? Just use the command c/v key combination for copy and paste.
Ok I pasted the code in the HTML mark up window and it does this
copy and paste.
Change the filename of your page from index.html to index.php and upload again. (You do this in the Inspector, in the left-most tab, while the page is selected.)
OK I changed the file name to index.php and it now does almost the same
thing but the whole page is just black and white code
is selected.)Walter
I got my own terminology mixed up. It should be a markup item instead of HTML markup item. Once you change it to PHP it should work if the tags are right.
OK I changed the file name to index.php and it now does almost the same thing but the whole page is just black and white code
Is it not the case that Mobile Me sites do NOT support PHP?
If so then you will need some PHP enabled server space somewhere to see this working.
Ok thank you
thing but the whole page is just black and white codeIs it not the case that Mobile Me sites do NOT support PHP?
this working.David
Do you know how what you have to do to make shure you are not breaking the
law when buying and copying movies to sell
this working.David
