[Pro] How to use Site Mapper Action
What “Priority” does the Priority: setting change (1-10 scale)?
Robert
Hi Robert,
The setting is the priority of the specified page relative to other pages on your site. It allows you to specifically tell search engines that some pages are more important than others within your own site. The default value is 5 and sets all of the pages with the same priority ‘weight’.
By setting your contact page (for example) to 10 you are telling the search engine that this content is more important than other similar pages - assuming the engine would have to pick between this and another page on the same site when displaying the search results.
Tim Plumb
Creative Director
Softpress Systems
Follow us on Twitter: http://www.softpress.com/tny/064
Join us on Facebook: Redirecting...
Looking for a webhost? We love these guys: Softpress » Web Hosting Partners
Tim,
Thank you.
Robert
Thanks again,
Emilio
I’ve submitted site map as in above screen shot, but Yahoo never checks green. it just hangs. Any suggestions?
Roxane,
I too get that hanging. Once or twice useing refresh the check has appeared. You can also have a web masters account with both Yahoo and Bing as well as Google.
Frank H.
I still can not find what I have done wrong. http://elysium.aswebsitedesign.com/engravetwo.html
I’m getting the same Yahoo hang. Perhaps Yahoo have changed something and the action needs to be updated?
Hi
I have submitted this as a problem to support at Softpress Towers back end of last week.
Regards
Lee
On 12 Nov 2011, 4:24 pm, Gray Owl wrote:
Hi
Regards
Lee
Hi All
Have just got this back from Softpress: thanks for pinging this out to us. It look like Yahoo have moved all their search stuff to Bing So we need to remove Yahoo from the Action. As Yahoo are now using Bing for their search then as long as your site submitted fine to Bing then people should find your Site with no problems and you can ignore the spinning bar for now.
I hope this helps.
Chris Sowley
Support Technician
So that answers our question. Thanks Chris at Softpress.
