Mr_worm
(Mr worm)
October 23, 2013, 11:45am
1
I have an old site I wish to update…
it consisted of several pages, however I have consolidated it into 1 page (index.php)
With regards to a 301 redirect… I want to move users from the old page;
http://www.example.com/aboutus.php
to the new one;
Whats the magical .htaccess line???;
redirect 301 /aboutus /???
Worm
Google probably? Found this - am not sure if it’s helpful:
Quickly generate an htaccess file for many functions including www rewrite, hotlink prevention, custom error pages, caching, and redirects.
Try and report back.
Tim_Plumb
(Tim Plumb)
October 23, 2013, 12:14pm
3
I wrote this article over on the Softpress KnowledgeBase a while ago that should cover what you want to do;
An .htaccess file is nothing more than a simple text file but one that offers a vast amount of power for users running their web sites on an Apache server. These tiny files are the hidden, and generally unsung, heroes of web designers, offering them...
I think it would be nice if Freeway knew the links had changed and offered to update the .htaccess file for you but it isn’t that hard to do manually.
Mr_worm
(Mr worm)
October 23, 2013, 1:38pm
4
Thank you Thomas, thats a really cool site!!! Very helpful as always
Tim, I read this earlier… however it does not illude as to how to redirect http://www.example.com/aboutus.php back to http://www.example.com
As I mentioned the site is now only 1 page, thus every old page needs to re-direct to the new single index page.
whem I try using Redirect 301 www.example.com/aboutus.php /www.example.com/index.php
I redirects to http://www.example.com/index (which doesnt work)???
and not…
How can I achieve this as neither seen to explain this?
Many thanks Tim
Worm
Caleb_G1
(Caleb G)
October 23, 2013, 3:59pm
5
Chris,
Give this a try:
RewriteEngine on
RewriteCond %{REQUEST_FILENAME} !-d
RewriteCond %{REQUEST_FILENAME} !-f
RewriteRule . index.html [L,R=301]
(Source )
That should redirect any requests to a file that no longer exists to index.html
Mr_worm
(Mr worm)
October 24, 2013, 8:44am
6
Hi Caleb, unfortunately that didnt work???
I’m confused, I thought this would be a pretty easy process, however its proving to be quite a chore…
I simply want all old/previous links to now redirect to 1 page:
www.example.com
thus
www.example.com/contact.php
so on…
will redirect to:
www.example.com
Many thanks
Worm
add this to a .htaccess file…
Redirect 301 /myoldpage.html http://example.com/mynewpage.html
David Owen { Freeway Friendly Web hosting and Domains }
http://www.ineedwebhosting.co.uk | http://www.PrintlineAdvertising.co.uk
www.example.com
thus
so on…
will redirect to:
www.example.com
Many thanks
Worm
Mr_worm
(Mr worm)
October 24, 2013, 4:27pm
8
David, that worked at treat!!!
Thank you so much
Worm
