[Pro] htdocs
This is probably a very elementary question. I have completed the pages of a web site called The Dining Room. The index.html page is in a folder in my Documents called ‘Web Folder’ I need to put it in a file called htdocs to upload to my hosts server. Do I create a folder in my Documents called hdocs and then do ‘save as’ to that folder? Working on Mac OSX 10.6 and using Freeway Pro. If I do this will it cause problems with the existing web pages?
The htdocs folder is most likely already there on your web host in your root directory. Have you tried loging in with an ftp client to see what is there?
If the directory is there, just make sure you tell Freeway where to find it in the document setup.
As Chucka says this should be set in your FW doc under File>Document Setup>Upload
So in Server: you would have www.yoursite.com
Then in Directory: /htdocs (which is the path to the htdocs folder)
username and password as you were supplied by your host
And then you can use FW to do the upload for you sending all your web pages etc up to the htdocs folder on your server.
Hi David,
Thanks for your reply, I have done a ‘save as’ of my index page and called
it htdocs so I have a copy
of my web site in my Documents folder with that name. I have not yet
uploaded the site FTP to
my host server, so what you say may work out when I do so and Freeway will
create a htdocs
Directory anyway is that right?
David Judd
Setup>Upload
In FW, keep your home page as index.html (do note rename it) then follow Davids step-by-step in File > Document Set Up.
This will upload your site to the htdocs (which is probably already there). The htdocs folder is simply a folder that the web browser will look in to find your index.html page
For things like this is might be worth getting an FTP application so you can see exactly what is on the server.
There are a few around - Transit, Fetch etc. It really does help.
Nathan Garner
Creative Director
Austin Wells Design Limited
One Elmgate Drive - Littledown - Bournemouth BH7 7EF
t 01202 301271 e email@hidden w http://www.austinwellsdesign.co.uk
Member of NAPP | Zen Affiliate | Dorset Business Member | YEC
On 6 Feb 2010, at 08:59, D Judd wrote:
Hi David,
create a htdocs
David Judd
Setup>Upload
Hi Nathan,
Nathan Garner
Creative Director
Hi David,
called
will
create a htdocs
David Judd
Setup>Upload
pages
Or Cyberduck which is free http://cyberduck.ch/
At the very least should have a look at your server so that you can see the file structure there - using one of these - and once you understand better you can let FW do the uploading for you.
And then it is a ‘no brainer’
and Freeway will create a htdocs Directory anyway is that right?
That folder ‘htdocs’ will be there already and you DO NOT want a FW created one to try to overwrite it.
To clarify further, the folder that your web site files go into can
be called whatever your web hosting company decides. Sometimes it
will be “htdocs”, sometimes it will be “www”, sometimes it will be
named after your web site domain name, and so on. The “htdocs” name
is fairly common but there is NO specific standard name - it is just
whatever your site’s ‘web root’ (the starting point or ‘root’ level
of your publically-accessible web site) is called.
You need to know the FTP details for uploading to your site. If you
log in using Transmit or CyberDuck with just your FTP address,
username and password you may go straight into the web roote, or
you may need to click into a folder.
When you log in, if you find yourself at the point where your HTML
files should go then you can leave the Path field blank in Freeway’s
upload dialog. But if you need to click into a folder first, put that
folder’s name into the Path field in Freeway’s Upload dialog. That
simply says “go to this place, log in, then go into that folder
before starting the upload”.
Hi Keith,
Thanks for that explanation, I have used that CyberDuck programme, and
dispite the silly name, it’s not a bad programme.
I have now successfully uploaded my website, and it’s not looking bad, have
a look at www.thediningroom.org
Best regards David
To clarify further, the folder that your web site files go into can be
called whatever your web hosting company decides. Sometimes it will be
“htdocs”, sometimes it will be “www”, sometimes it will be named after your
web site domain name, and so on. The “htdocs” name is fairly common but
there is NO specific standard name - it is just whatever your site’s ‘web
root’ (the starting point or ‘root’ level of your publically-accessible web
site) is called.
You need to know the FTP details for uploading to your site. If you log in
using Transmit or CyberDuck with just your FTP address, username and
password you may go straight into the web roote, or you may need to click
into a folder.
When you log in, if you find yourself at the point where your HTML files
should go then you can leave the Path field blank in Freeway’s upload
dialog. But if you need to click into a folder first, put that folder’s name
into the Path field in Freeway’s Upload dialog. That simply says “go to this
place, log in, then go into that folder before starting the upload”.
Hi David
It is looking good but just thought I would mention a couple of things
“…whilst doing her studies that she worked evenings and weekeds at Caffe Uno”
Also on a couple of the pages the links dont show in the navigation menu in the visited state ie roll over Mains and Location when on the Desserts page.
Is your Navigation on a Master page - if not it should be - and remember to only update it on the Master.
Hi David,
Thanks for pointing those things out. I must check them. I am trying to keep
the menu etc to the Master Page etc.
On the literals I have to make sure that all spelling etc is correct that is
always important. I have also
Downloaded CyberDuck FTP programme and will try and use that to check each
page uploaded to the server.
Kind regards from an elderly novice David
On 8 February 2010 00:32, DeltaDave email@hidden wrote:
Hi David
at Caffe Uno”
and will try and use that to check each page uploaded to the server.
Once you have FW’s upload settings correct then there really is no need to use any other FTP package on a day to day basis.
