[Pro] html box positioning
Hi,
I have an item which appears several times throughout my website.
I would like to make the positioning uniform.
Ideally the html item which sits within another html item should always appear at the bottom of the first html item ?
If this makes sense? Is there a way to do it ?
To clarify,
I have 3 boxes next to each other each with different content.
I have added code to the extended option to ensure the 3 appear the same height.
Is there some code I could add to the extended options for the html item to ensure it is always displayed at the bottom of the main box.
This way, the items will appear much neater on the page.
I guess I need to try other avenues ?
Can you post a link to the page where you’re having the problem?
Hi Walter,
wet rooms direct dot net/Formers/showerdec.h t m l
The PDF icons. I would like them to appear at the bottom of the html box they sit in.
You should be able to do this by drawing the icon over the top of the
HTML box (so it becomes a child of that box), and then manipulating
the bottom distance to place it where you like. Try this: Click once
on the left box, then while it’s still highlighted, choose the HTML
box tool and click and draw a box directly over the left box. The
outlines of the left box should highlight with a blue glow to indicate
that you’re getting the desired effect. Then drag your icon image from
the Finder into that new inner HTML box. You should now be able to
manipulate the distance from the bottom of the box to the bottom of
the icon.
On Jul 6, 2010, at 5:46 PM, NeilMT wrote:
Hi Walter,
box they sit in.
