Nothing. Nothing at all. You have breached Freeway Pro’s vertical limits.
There is a whole thread on it -
http://www.freewaytalk.net/thread/view/134075#m_134075
What I ended up doing was inventing some very advanced techniques to reduce
the appearance of the size of items in my layout (mostly images). Here is
my former “problem” page - http://industrialmarketing.com.au/drillrigs.html
The image for each item is pass thru and full-size in the FWP workspace,
which is how I quickly breached the limits. You will also likely find that
even though the max page length is 32,767px, you should be seeing weird
things happen when scrolling workspaces longer than 19,999px.
If you cannot severely reduce your workspace length, then I will suggest
breaking your “page” up into individual pages… it’s a problem only with
FWP, as web pages can be much longer than that without breaking the
browser. You can try something known as Server Side Includes (SSI) which is
a little technical but eminently doable. Tim Plumb has a sweet little
action that helps with the heavy lifting, but is still technical and is
best to get the hang of before using as a solution.
Less than 5 of you will be interested to know that my solution involves
using a small generic FPO image to conserve space, then Extending the img
src to the Resources/filename.jpg which is uploaded full-size where it is
used on the item’s feature page. So I am getting the same effect with far
less space - and have reclaimed enough on that page to regain FWP’s full
functionality.
On Mon, Oct 14, 2013 at 1:18 PM, jgalicia email@hidden wrote:
I have innline content but when I want more space this error appears
“The value is greater than the allowed maximum 32767px; previous value
substituted.”
I can do that will let me do it bigger?
