Draw a single HTML box where you want your menu sidebar to appear. Cut
each image in turn, and paste it into the HTML box as an inline
element, followed by a single return. When all of the images are in
the box, you should see them stacked one atop the other.
Now if you don’t currently have a text cursor in that HTML box, double-
click so you see one flashing away, ready for typing. Use your arrow
keys to place the cursor after one of the images, then press return
again. TYpe in the first submenu item, return, second, etc. until you
see something like this:
[EVENTS]
Foo
Bar
Baz
[GALLERY]
Highlight the text you just typed, and use the Inspector’s List
segment to turn those items into a list (click the right-facing arrow
in the Inspector to indent one level).
Click once on the HTML box and apply the ScriptyAccordion Action to
that box. Set the Trigger Event to Click/ Set the Trigger Element to
img and the Show/Hide Elements to ul. Turn off the other options for
now.
Preview. Your first list of elements shoult appear and disappear when
you click on the image header Events.
You can tighten up the vertical spacing by creating a new style using
the Styles palette, and setting the Paragraph attributes Space Before
and Space After to 0px. Then double-click inside your HTML box, use
Command-A (select all) to highlight all of the text, and click once on
your style name in the Styles palette.
On Sep 12, 2011, at 10:31 AM, Lena wrote:
I was here a couple of weeks ago inquiring about how to create an
accordion menu and got great suggestions from many on these forums.
I like the scripty accordion but I have no clue how to incorporate
it. I followed the directions as per the creators instructions but
it doesnt work for me—at all!
Here is my very simple website: http://lenaosoriogemisic.com/index.html
. If you click on EVENTS, you will notice that there is a menu list
on the left side of the slideshow. I am trying to incorporate the
accordion menu on this element. At the moment, each element listed
in the menu is in its own graphic box. I tried to recreate it my
making an HTML box and making it a list. Under the WEDDINGS menu
there would be three hidden elements called: Modern, Vintage &
Romantic. Each of these will have their own links. I simply cant get
it to work. What am I doing wrong or what should i be doing? The
Scripty Accordion action is not working out for me and I have no
clue why? Please help! I have been dealing with this for days and I
am beyond my wits end.
