My Iframes wrap in Safari but will not wrap or scroll in IE9.
Example?
The problem was that the text files were .txt files. I changed the to to .html files and everything worked. The files don’t contain any html code they were simply a description of up-comming events.
So you were trying to display .txt files in your iFrames?
Generally an iFrame is used to display a whole html page within an existing page.
To do what you were trying to do usually involves the use of a PHP include to just bring in text to a pre-formatted container.
