OK Walter, I see.
So any clues as to how to solve my overflow problem?
I am using iFrame to link to a page of event dates (that I shall eventually link to a MySQL database).
When viewed on my laptop, that works fine. On iPad, the list flows out of the frame.
I could really use some help. The site is at test.henshallcentre.com
Keith
On 11 Feb 2014, at 11:08, Walter Lee Davis email@hidden wrote:
-webkit-overflow-scrolling does not do anything for iframes. It only governs HTML elements that have their overflow
style property set to auto
or scroll
On Feb 11, 2014, at 11:03 AM, Keith Henshall wrote:
David,
That didn’t seem to work.
Just to check I haven’t done anything dumb:
I went to Page>HTML Markup>Before and entered:
#item8 {
-webkit-overflow-scrolling: touch
The item that has the iFrame action applied to it is, in fact, called item8. (I also have overflow on item12.)
Did I get something wrong?
Appreciate your help.
Keith
On 10 Feb 2014, at 16:45, DeltaDave email@hidden wrote:
Try the following added into Page>Html Markup in the before section where item8 is the name of the Div that holds the iFrame
<style type="text/css">
#item8 {
</style>
