Is it possible to use image maps that link to other pages within a Carousel 2 or a Carousel 2 pane? If so, how is that accomplished?
What have you tried so far? It may just work. If you can’t get the image map to work, what will definitely work is this:
Now publish and preview in a browser.
I only tried using the image map tool, which doesn’t work. I’ll try your solution instead.
Kelly
Worked perfectly. Thanks Walter.
