I have a sequence timer that is rotating 7 images. The first images that comes up has nice, rounded corners but the others don’t. I have spent an hour trying to figure out why they are different when all the specs say they are the same.
Also, there is a slight shift from image to image.
How are you creating the rounded corners on the image - are you using the graphic item style palette?
If so you actually want to use the CSS3 Corners action on the an html container that contains the graphics. I think I would create the different layered containers and use the graphics as centred background images with the CSS3 Corners and CSS3 Shadow action applied to each.
