[Pro] Importing CSS From iWeb
Hello everyone,
I’m trying to convert one of my sites from iWeb to Freeway because I need to use forms and run scripts. I’d like to capture the look and feel of the iWeb site as closely and as painlessly as possible, so I imported the CSS from one of the iWeb pages into Freeway’s styles. Seems to have worked, but when I create a new HTML text item, the body style is not applied. Not sure how I can get Freeway to start using the imported sheet as the default. Anyone had any experience with this?
Much obliged,
Gregory
When importing CSS into the styles Editor in FWP you have to go through each imported style one by one to make sure that ALL the CSS was brought in. It is frequently the case that much of the special styling does not come in. This is primarily because much of the CSS is not standard to FW and can only be added with the Extended option in the editor. So, basically, you will have to manually add the missing style settings per each style you imported that is incomplete.
Use CSS Edit if you have it available to check what all the different style settings are in the iWeb styles, then poke around in the FW editor to add what is missing via the Extend option.
Thanks Chuckamuck,
Good stuff!
Gregory
