Some of the thumbnails to the right of the main photo are not clicking through to their respective pages even though all the images are linked in the freeway document.
All those working have (on the code side) a #map applied, whatever a map is. Unfortunately, this entire layout is broken down to a table-construction and I can’t debug such a beast.
Another problem on this is, that I’m not aware how this page will be responsive one day, do you?
As a small tipp for the future:
AVOID - whenever you can (up to 100%) spaces in filenames and folder names to prevent you from things like:
mydomain.com/my%20subfolder/a%20file%20name.html
Use dashes (is it the correct word?) instead
mydomain.com/my-subfolder/a-file-name.html
or even
mydomain.com/mysubfolder/afilename.html
But on all the rest, I hope that some experts rushing in helping out what may cause some of those disfunction’s.
Having had a further look into your head markup and think that you have to adjust a couple of things there immediately:
####Keywords
Twice in head. Remove one or both cause they have no relevance anymore. But if you use, make sure just to use 6-8 of them AND all of those preferably are reflected in the page-text which doesn’t exist yet.
####Description
As well here, max 150 characters, the rest will be truncated anyway. The description reflects the first body paragraph - content in page if you want so. No body text, no real matches no good ranking.
Be careful with such things. It is more efficient to create stronger styles (Headings) to structure a page. Get used to those basic page structure as an inevitable component of successful and semantic web design.
Hm - I meant to read somewhere, that underscores are often preserved for script languages or may even confuse them. So I think hyphenating is still the better choice. But I may fail.
Hyphens in filenames are treated as separate words by search engines when parsing the filename for keywords. Underscores between words are treated like a single run-on word. In a script, the only thing that happens when you use a hyphen within a variable is that the part after the dash is subtracted from the part before it, leading mostly to logic errors. Always use underscores in place of spaces within variable names, for this reason.
A map is used to provide a link on a photo that does not wrap around the entire image area. This is how you can click on your neighborhood within a larger graphic of your county and have the little popup showing you the postal code, for example.
