[Pro] importing to Freeway error
Hi, I’m importing a slideshow to Freeway and I can see the thumbnail when I import it but when I click the Browser button to preview the page I get the following error…
Action Exhibeo import el has no properties.
I have no idea what “el” refers to. Accepting the error, I get the message…
Could not complete the ‘Publish Site’ command because a JavaScript error occurred in a Freeway Action. If you republish your site the Action will be ignored.
Any ideas? Thanks
Exhibeo mailing list
I’m having the same problem. Were you able to solve the issue? If so how?
Check having the latest action version!!!
Hi
How do I get the latest Action version?
Best
Heather]
There are no options for Install Freeway Action showing in Exhibeo, which is what the KnowledgeBase says to do.
Do I need to delete the old action first to get this to work?
I can’t find any other information, will google more, but would be good if someone can give me a quick answer!
Ta
Heather
Went to the Exhibeo website but the action there has to be the old one, it’s dated 2013… Grrrrr!!!
Exhibeo → Help → Install FW Action for Exhibio??? The lastest version number is for me 1.0.6 however I can’t say if it is the lastest one.
Hi Thomas,
That doeesn’t work for me. It was the first thing I tried and I get Exhibeo>Help> blank. If I type Action nothing comes up.
I wish it did work though!
Heather
Hi Heather,
hm - this sounds strange. Assumed using the latest EX version, the dialogue should show up, does it? If not, worth a quick talk to the tower’s support. I am under the impression having heard of this but can’t remember correctly. Report back what the guys said.
I am just wondering, WHY (???) since Freeway Pro v7 is a such a nice piece of software, WHY, there is no improvement for Exhibeo … I am talking improvement which will elevate Exhibeo on very serious presentation software …
You guys, you may call it Exhibeo Pro if you like you can charge 49.00 if you like, but I am sure, that many people will be delighted to own it.
