First off, not sure why your message didn’t get accepted. Not a feature of this system – there is no such thing as a “locked thread” on the mailing list.
By the looks of this directory, you are using a Windows hosting server. I have no idea if this will work at all, because the features that Inlay uses are specific to Apache servers, and Windows almost always uses Internet Information Server (IIS) in its place. If you find that you cannot make it work, it is doubtful that anyone could!
The correct place to put these files is the wwwroot folder (if I am reading that correctly). As the instructions say, it should go in the same folder as the index.html file for your site.
Don’t miss the part where you rename the _htaccess.txt file to .htaccess. I do not know if IIS uses .htaccess files to configure itself, or if it includes the mod_rewrite module which Inlay requires in order to work at all. So this may be a very short trip.
If you can, move the site to a “normal” server: Apache running on Linux or Unix. IIS is a vanishingly small slice of the hosting world, used only by people who have a compelling business reason to do so (integration with proprietary business applications, mostly) and who can afford the constant maintenance and security patching that it requires. It is generally very costly compared with equal- or better-performing *nix equivalents.
If you can’t do that, then I will be happy to refund your account. I don’t have any plans to port this service to ASP (which would be native to IIS/Windows Server).
On Jul 25, 2017, at 10:53 AM, Misty Ann email@hidden wrote:
I had a post regarding Inlay that will not accept any new posts for some reason? I posted this yesterday but it disappeared. Hopefully someone can help with this. I am wanting to make a page on my website editable by my salesmen and have decided to use Inlay. I signed up for Inlay, downloaded the .zip file and had already downloaded the Inlay action. I’m confused as to where I upload the 2 files (_htaccess.txt & _inlay.php) that the Setup Instructions say to upload to my Web Server. I logged onto my hosting service and went to the Access Site Admin Panel which shows all the folders for the website I assume. Under the Root Folder are these folders: [Parent Directory], [This Directory], Inetpub, LogFiles, mssql, reports, Users & webalizer. Under FTP Folder are: [Parent Directory], [This Directory], LocalUser, logfiles & wwwroot. In the Root Folder under Inetpub there is a ‘wwwroot’ folder that contains the index.html file along with the .html pages of my site. Those files are also in the FTP Folder ‘wwwroot’ folder. The path in the Root Folder is: InetpubWwwroot and the path in the FTP Folder is: InetpubFtprootWwwroot. So not sure which one the files get uploaded to or if they even get uploaded to those folders at all?
Thanks for any help!
Misty
