Hi everyone. I want to insert some ad code as per the following instructions:
Open your site’s main page (i.e. - template file, or header file) in an HTML editor.
Search for " <body " within the HTML and insert the Ad Code immediately after the close bracket of the body tag " > ".
Once done, make sure to Save the changes to your HTML.
How do I do this in FWP 5.5 (I don’t have an HTML editor)
Alternatively if you want this ad to appear in a specific place on your page try Insert>Markup Item and paste the code in there. Position the resulting box on your FW page where you want the ad to appear.
One more thing… the ad works fine now, but it takes the viewer away from my site when they click it, whereas I want them to stay and for the ad’s destination to open in a new tab/window. The Spawn New Window action does not do it - the ad isn’t a simple URL but contains affiliate info similar to this -
From what I can see the ad is being served with the link created already and so you have no control over the link to change it to open in a new window.
Unless there is a fancy JS method?
Affiliate Windows T & C may also disallow you to do this.
