[Pro] Inspector window not showing.
Hi guys,
Just got back to Freeway Pro 7 tonight after quite a few weeks away and discovered the inspector window does not show up in either my saved projects or creating a new one - clicking on the inspector button does nothing. I have re downloaded and installed but still no change. Still running on Mountain lion so not sure what is happening. Has anyone else experienced this and any ideas to fix?
Thanks.
Do you mean the inspector panel?
Using the keyboard shortcut… Alt-Command-i
Or Menu > Window > (select) Inspector Pallet
What do this do?
On 13 Oct 2018, at 15:31, Mark Spivey email@hidden wrote:
Hi guys,
David Owen { Freeway Friendly Web hosting and Domains }
http://www.ineedwebhosting.co.uk | http://www.PrintlineAdvertising.co.uk
Hi David,
Solved the problem! I have a Wacom DTI 520 drawing tablet plugged in but not always powered on. Seems that sometimes windows get moved and display on that screen. This morning I turned that screen on (usually it is off) and there were my missing inspector windows…
