[Pro] intergrating adobe bridge into freeway
Hi
is adobe bridge easy to use with freeway?
Also I hear there is an option in bridge to upload directly from the app straight into the web hosting folders.
how would this work with freeway and how would i get the pages to connect with freeway if they we’re uploaded directly from bridge?
or is there another way which is easier to do?
many thanks
Peter
I used this method before for a client that wanted to maintain their own slideshow. You can fill in the ftp details in bridge and direct that to a specific folder. In Freeway paste the code in a markup field and it will show that external slideshow. Yes, it’s easy, but with the new program Showcase that comes with Freeway I think this is an easier way.
Hi DTP2,
thanks for this,
where do you find the code in bridge?
Peter
It has been a while ago, but I was wrong about the code in the markup field. Bridge creates a folder with all the necessary files and an index.html file. Use the iframe action to show this index.html page. No extra code needed.
thanks,
sorry not used iframe action before where do i find it in freeway?
and do i drag the index.html file into iframe action or open?
thanks
Peter
Please read this article iFrame - Freeway - Softpress Talk and I think you will be fine. If you still have issues after that, please let us know.
Hi
I’ve tried the iframe. but no joy.
I’ve uploaded the gallery directly to the website in folder marked photography.
Inserted iframe and opened index but just getting the following result.
http://sarahotoole.com/photography/untitled1.html
just small section of writing below the artist photographer and designer.
Should I be specifying a different folder?
thanks for all your help on this
Peter
Please check if that folder (photography) really exists on your webspace and if there is a file called index.html and a folder called resources in that folder? These are the files generated by Bridge.
Because now if I browse to http://www.sarahotoole.com/photography/index.html I don’t see your gallery and it should be there based on your information.
If these files are not in there it can not work.
Hi the files are there on the web server
the home page is
how do I connect to those files on the web server?
thanks Peter
I downloaded all the files from your webserver, but you are doing something wrong in Bridge.
You should choose output to web, choose web gallery and there you have the option to publish it on your local disk and upload it yourself of to fill in the correct credentials for your website and space and upload it automatically. Bridge should create a file called index.html and a folder called resources.
First make sure these files are created correctly and on your webspace in the folder photography.
Hi I’ve,
uploaded a new gallery called sarah web gallery 3 and uploaded it to the webserver in folder called photography.
I’ve also saved a copy of the file to the desktop. It has index.html file and resources folder.
what’s the next stage?
Thanks for your help on this. I really appreciate it.
peter
I would like to advise you use an external ftp program (like Cyberduck or something) and manually upload the files you have on your desktop (index.html and Resources folder) directly into the photography folder on your webspace.
Reason is when I look on your webspace the correct files still are not on the photography folder. I think you did not fill in the correct details in Bridge.
After that if you check the url http://sarahotoole.com/photography/index.html should already show the gallery. If you see the gallery you can switch back to the iframe article.
Ok will try this and let you know.
thanks
Peter
Hi,
I’ve uploaded it via cyberduck and its on the server. all the files appear to be there.
I can send you a photo grab of file if that would help.
Peter
Please do provide us with a screenshot of the files you have in your local folder and of the files on your webspace.
Because if I pull all the files of off your webspace they still are not in the folder.
What is your email so I can send an attachment.
thanks
bart at dtp2 dot nl
I am back with this question again. I design my website and i added a adobe bridge gallery to my site and i used iframe and it is not linking to the file on my server. Can someone please help.
Hi,
I’m pretty sure not without any further information such as a link or similar.
It sounds without any further thoughts like broken paths to the images/scripts/Resources whatever. Is there any reason why you use adobe bridge and not for example showcase?
Not having used Bridge i have to assume that it creates a folder and within that folder is an index.html file and image files/folders
All the files/folders created by Bridge should be uploaded via an FTP app to your server and placed in the same relative positions to each other.
It should then be as simple as using the URL of the Bridge index.html page in your iFrame action.
But posting a link to what you have on the server will help us to see exactly what is going wrong.
