Using Pro5, I am creating a page using multiple graphic files stacked. Problem is, I resize one graphic, all the others change size as well. When I try to select the back image, the other ones get selected as well. I also cannot drag the smaller “slaves” away from the backmost big image,
What am I missing? I have “combine graphics” turned off, images are not grouped. Since I am using it to build an html email, I have html 3.2 selected, but the problem remains even if I change the html version.
Hi Bjorn,
Can you email your Freeway document to support(at)softpress.com? It sounds quite odd but I’m sure there’s a reasonable explanation.
Cheers,
Chris Sowley
Design Monkey & Problem Solver
Freeway: You create, it codes
It’s a large file, so might be tricky, maybe screenshots will do.
Sure, but if that’s not enough for us to work out what the problem is then you might need to send it with WeTransfer http://www.wetransfer.com.
Chris Sowley
