Hi chaps … when I view this site in my ipad - if I point/click on the slideshow image the auto-mix between images stops and I cannot start it again … any thoughts please ?
Roger
http://www.christchurchview.co.uk/christchurchviewgallery.html
Exhibeo mailing list
Are you working on it just now coz there is no slideshow visible.
Really sorry Dave, silly mistake, I must have posted the wrong link … it’s the index page:
Well interestingly I think I’ve solved it, by chance I came across another thread re. iFrame in which Waltd suggested:
“Draw your iframe, set it for your content, then draw a second layer over the top of it (just an empty HTML box drawn while the CSS Layout button is on). The layer will capture any clicks, and they won’t pass through to the underlying iframe.”
Well it worked for my ipad problem as well … thanks Walt.
Roger
As an aside - your site crashed my iPad - but it is a first gen!
Mine’s a second gen and I had a problem, before I put the empty html box over the top of the Exhibeo page, in an attempt to start the ‘animation’ again I hit the refresh button in Safari and the page went white and Safari crashed, it’s been ok since … what can be wrong with a site to cause it to crash Safari or, more importantly, an iPad ?
Roger
I am putting it down to mine being too long in the tooth with Safari stuck at too basic a level.
I am struggling to run newer apps which more and more seem to require at least iOS6
Aaaargh!!! I need a new one.
You’re probably right about it being a little infirm (just like me) … there’s a very very long thread here that looks at the problem:
https://discussions.apple.com/thread/2460899?start=945&tstart=0
… I gave up after two pages !
Roger
