Hey guys,
Sorry to push, but could anyone help me with this issue. I’m sure it’s something simple but i can’t work it out.
When i view my site on an iPhone or iPad the homepage loads in a random order and some of the text isn’t there at all.
What’s strange is that this used to work, and I haven’t changed anything. Please help!
Very kind regards,
Mark Lawrence
www.thebookstheworldwrote.com
Joe2
(Joe)
November 14, 2013, 11:59am
#2
I’ve never seen this happen before, but what could be happening is that the iPad, for whatever reason, doesn’t like the combination of table and layer based layout. I would recommend either making all of the items on the page layers, or all of them table based – not a combination of the two.
Hope this helps,
Hi Joe,
Thank you for getting in touch, I’ll go through my file and ensure everything is a layered and get back to you.
Will keep you posted.
Mark
Hi Joe,
That did the trick. Once I’d changed the twitter html markup box to a layered object it solved the problem.
Thank you again for your help.
Mark Lawrence
