Freeway uses a less processor-intensive image resampling technique
known as bilinear sampling, versus Photoshop’s more impressive bicubic
sampling.
Freeway is constantly resampling your images when you resize them,
crop them, etc., so this time savings is an investment in your
everyday working speed.
For many images, it does a fine job and there’s no need to “sweeten”
the images. But for those cases where this compromise cuts too deep,
what I like to do is make the layout in Freeway, get everything
looking the way I want it to, then open the Freeway-generated art in
Photoshop, drop the full-resolution original on top of it, and
resample the image in Photoshop – to size – and use the Save for Web
feature to create the final art.
Back into Freeway, select the image you want to replace in your
layout, and import again, this time targeting the Photoshop-generated
original and checking the Pass Through checkbox in the import dialog.
Now the trade-off is that you can no longer change the dimensions or
any other aspect of the image except its position. But the benefit
will be that you get the full power of Photoshop to make your
production images.
On Apr 1, 2010, at 4:10 PM, chickdesign wrote:
I built a small site for a designer in Freeway Pro. She gave me PSD
files which had background gradations which Freeway didn’t handle
well, there was too much banding. So Freeway Talk community members
suggested using some Noise in PSD to decrease the banding. That
helped. The site was finished and published.
Now the designer has had the same site with the same PSD files built
by someone else in Dreamweaver. The Dreamweaver version is showing
much more brilliant colors on the same artwork, almost as if they
are backlit transparencies. Also, the gradation in the page
background seems much smoother than how Freeway handled the same file.
Is Freeway Pro having trouble matching the image quality of a site
built in Dreamweaver? Has anyone else had a similar experience?
Patty
