Hi all and thanks for your attention.
I use an rss feed service (rssinclude.com) and cannot work out how to style the output. Can someone please advise if it’s actually possible (rss include say it is), and if so point me in the right direction?
I work around styling currently by pasting the markup item in a styled paragraph, but I would like a little more control!
Specifically can someone advise how to create style classes for the output? I have tried simple styles “rssincl-itemdate” for instance with no result.
I would like to be able to reduce the font size for the date element “rssincl-itemdate”, and add a “width 100%” class to the image to make it scaleable (or is there another way of doing that?).
The input code looks like this (actual example):
<p class="Content"><script type="text/javascript" src="http://output56.rssinclude.com/output?type=js&id=1035824&hash=22ceec41cbe15510fdf4aada0dea91ef"></script>
</p>
The output curently looks like this:
document.write(" <div id="rssincl-box-1035824">n
<div class="rssincl-content">n
<div class="rssincl-entry">n
<p class="rssincl-itemdate">n November 5, 2015 </p>n <div class="rssincl-itemimage">n
<a href="http://sunshinecoast.peterhyndman.com/2015/11/cluster-housing.html" target="_blank"><img src="http://4.bp.blogspot.com/-1EG1nakT7FU/VhZnM18frAI/AAAAAAAAPAM/56BUo04LP3Y/s640/Oct-Nov-5.jpg" alt="Cluster housing." title="Cluster housing."n width="295.00" height="166" /></a> </div>n
<p class="rssincl-itemtitle">n <a href="http://sunshinecoast.peterhyndman.com/2015/11/cluster-housing.html" target="_blank">n Cluster housing. </a>n </p>n <div class="rssincl-clear"></div>n </div>n </div>n
<!-- RSSbox id#1035824 powered by RSSinclude.com -->n </div>n");
Any help at all will be greatly appreciated!
Cheers,
Peter
