Hi,
Is there a way to do this
Images panning left/right without using Flash?
Ta
Hi,
Ta
Hi Justin,
This panning technique is commonly referred to as the Ken Burns effect;
I posted a very brief example a while ago of how to do this with Easy
Web Animator (http://www.softpress.com/products/companion/easy-web-animator/
) and export the animation to Flash;
Ken Burns effect
Searching google reveals a number of ways to achieve this using
JavaScript although all will have to be manually integrated into your
Freeway file;
http://www.google.com/search?q=javascript+ken+burns+effect
On 12 Sep 2010, at 22:27, Justin Easthall wrote:
Hi,
Is there a way to do thisImages panning left/right without using Flash?
Ta
FreewayActions.com - Freeware and commercial actions for Freeway
Express & Pro.
Spam.
http://www.freewayactions.com
I have Bannerzest also, which will produce the effect (in Flash).
Great thankyou - Ill look at the options
J
The great thing about BannerZest Pro is that it does produce a Flash banner, but also an alternative banner that performs great on mobile devices as the iPhone or iPad. I use it all the time and am very satisfied.
True but it only produced a basic slide show not the effects (mobile device).
