I just uploaded one of my websites (www.cardioamigos.org) and, I don’t know why, my responsive css menu is not working on the phones/tablet. It does work perfectly on my freeway and on any computer browser, but when the screen gets small and the css menu display changes, then it stop working. I don’t know what to do since in my freeway works perfectly and it doesn’t seems to have a problem. any ideas? Thanks for your help.
You are missing the javascript that makes it do its thing. Try holding down the control key in Freeway and choose the hidden option File / Publish Everything. Then upload again.
On Jun 4, 2014, at 6:23 PM, Luis Bello wrote:
Dear Friends,
Hello Walter, thanks for your response and sorry for my delay in getting back to you. I tried what you told me but unfortunately there was no success. Any other ideas?
Hello Guys, I still experiencing this problem. I have tried everything. I even tried rebuild the css menu, but still doesn’t work. Any ideas? Please help. Thanks!
See that %2520 part there? That shouldn’t be in the URL of that script. See if you can locate the folder on your Mac, and rename it to remove any punctuation or spaces from its name.
If that doesn’t help, post a message to Tim Plumb at http://freewayactions.com and see if he can sort that out. I believe that part of the Backdraft kit was written by him. (I take all the blame for the Responsive CSS Menu Action.)
I regret to inform you that I’m pretty certain Tim didn’t do that bit - the only JS file loaded by his action is Respond.js for IE8 support.
Something to try would be to delete the Responsive CSS Menu header module from the “Extra Modules” page - I’ve got a sneaky suspicion that might be the root cause of this problem. Actually, I’ll just recommend that you take the Backdraft pages and pull them up into the master page section of the sidebar, then delete the “Backdraft Modules” folder. Hopefully, that will force FW to rewrite the javascript file that is causing the problem.
