[Pro] Item Locked outside page
I copied an HTML item from one page to this page and I couldn’t see where it landed when I clicked ‘paste’. Well, it ended up outside the working field and though when I zoom out to 25% I can see it I cannot ‘select’ it therefore I cannot remove it. Any other zoom is not enough to locate it. How do I get hold of it and delete it?
Thanks, Carolyn
http://edgarbarnett.com/analyticalhypnot.html
Just solved my own problem. I made the ‘page’ bigger while in 25% zoom and when it encompassed the rogue item I was able to select it and delete it.
Duh!
Carolyn
Another way to do that might have been to set the Site pane to show items.
Selecting the item in the Site list is the same as selecting it the
“normal” way.
