Hello All
In the above link I suddenly can’t get the two times to display correctly.
• Item; ‘item4a2a1’ is a background
• Item; ‘OurCookiePolicy’ wording is also not displaying correctly
Ive also tried the following:
• Force republish everything
• Save As …
• Delete and recreate each time as stated above
• Deleted from the server and re-uploaded
• Restarted the iMac
Any help would be appreciated.
Tony
http://goo.gl/qpEJiF
The first image (‘item4a2a1) is missing - should be at http://www.bajanapple.com/Resources/item4a2a1a.gif - but its not there!
Have you looked in your Local site folder (on your Mac) to see if it is being published?
Similarly for http://www.bajanapple.com/Resources/howtopayforyourpra.gif
HI David
Thank you for your reply. The above files are in the resources folder, however they just won’t publish.
Then remove them from the FW page - publish the page without them then re-import and publish again.
