[Pro] Joining cells
Hi folks, as a Freeway newbie please be gentle with me :slight_smile:
I have created a table 8 columns x 3 rows. How do I join the middle 4 cells on row 2.
I seem to be unable to select those cells.
AS a ‘newbie’ you’ve made the most important step - you’re not afraid
to ask for help.
Selecting your four middle cells is not difficult:
Select one of the cells then hold down the shift key and click on each
of the other three. They should all now be selected.
To join them (i.e. make them into one cell) click on the Item Menu,
then select ‘Table’ and, from the sub menu, Join Cells.
You should now have one large cell surrounded by 20 smaller ones.
HTH Colin
4 cells on row 2.
Thanks for your help ColinJA.
Problem sorted.
