I’ve been down this path, many years ago, and I can help you find your way. One thing to realize here is that Prototype and jQuery both do exactly the same thing, and to use both of them is a waste of either. Best approach is to start with “what do you want to accomplish” and then find a way to do that, rather than saying “I have to use jQuery because the AlphaBetaWizzbangWidget requires it”. Prototype is a very deep and powerful tool, too, used to build highly reactive sites. It’s a tool that builds tools, though, so it’s not a plug-in paradise. You could build jQuery with Prototype, but the opposite is not true.
Your footer code could be written like this instead (assuming Prototype 1.7 was already in the page):
var footer = new Element('div', {className: 'Footer'});
$$('body').first().insert({bottom: footer});
new Ajax.Updater(footer, '/cooppressH/common/footer.php');
And since you would not be blowing up the existing code by re-declaring $ to mean jQuery after Prototype already claimed it, your animations would still work.
On Dec 17, 2015, at 6:35 PM, Peter Kotz email@hidden wrote:
ok! yes freeway is a great tool … for lonesome designer … the problems start with bring in cms and crm and external code or working in a team
the code i bring in function, but the freeway design transition and scriptacolous stopped working … now i have to change to bootstrap or adobe dreamweaver or solve the problem to bring in a jquery in freeway (is this useful) … the “no conflict” do not work!
and thanks to David …
the actual problem is this code is working:
but he stopped all transitions and rollovers in the side … (not in all sides)
my question: is their anybody who designed a great extential freeway designed site with connection to a mysql database for write and read over php code … and if their is one … please help me !!!
Peter
