[Pro] juicebox pro
Has anyone experience with juicebox (the makers of “simpleviewer”) and freeway. I tried slideshow pro with freeway and could not get it to run, so I am looking for a good slideshow app to use with freeway pro.
Thanks, Tom
what kind of trouble did you have with showcase?
Compared with showcase, the manual implement of a script like this is about 100 times more complicated to do, to explain, to understand, to style and finally to get it to run.
And I personally can’t see that much advantages towards showcase or do I miss here something?
The main advantage I can see is that it’s much more customiseable - the Showcase and Exhibeo slideshows all look a bit rubbish in my opinion. Too many effects, not simple and elegant.
I used to use Simpleviewer slideshows all the time in my freeway sites - you can use an html item or an iframe to embed them, really easily. I stopped using it because it uses flash. I’m definitely going to give Juicebox a try…
