[Pro] Keybd Shortcut
Hi All,
In a similar vein to Doty’s thread about keyboard shortcuts, does
anyone know of a shortcut that switches between pages when working in
Freeway? This would be similar in action to a Back (or Forward) button
in a browser. Currently, I have to go down to the menu at the bottom of
the screen, and select a page from the pop-up list – all done with
clicks of the mouse (trackpad). Kinda cumbersome when switching back
and forth between the same two pages.
Thanks!
Richard
FWP 3.5.12
Command left+bracket and command right-bracket move between pages. (This is the Mac OS standard previous/next tab shortcut, I just tried it on a hunch.)
On Apr 3, 2012, at 4:17 PM, Richard Houston wrote:
Hi All,
In a similar vein to Doty’s thread about keyboard shortcuts, does anyone know of a shortcut that switches between pages when working in Freeway? This would be similar in action to a Back (or Forward) button in a browser. Currently, I have to go down to the menu at the bottom of the screen, and select a page from the pop-up list – all done with clicks of the mouse (trackpad). Kinda cumbersome when switching back and forth between the same two pages.
Thanks!
Richard
FWP 3.5.12
Yes, I did the same thing a few years back on a hunch and was happy to find it works. Now, I can leave the left menu in “Page” and sort back and forth between pages without having to return to the site menu first. Very very handy!
Doty
Based on this thread - I don’t seem to get what keys the shortcuts for increasing the graphic size (in the graphic box) are…
Julie
Doty
Same thing happened to me as it did for Julie - just shrunk my current page!
Elizabeth
Julie
Doty
To switch pages, you need to be sure not to have anything selected on the page. Hope this helps.
Doty
Here’s another kybd shortcut question: Is there a key modifier that
temporarily changes the Arrow Nudge amount from 1px to a larger amount,
say 10px?
Richard
Hmmm… Doesn’t seem to work for me. Maybe this was a feature added
after FW 3.5.12.
Richard
makes no difference, I checked that, I’m using current FW and Snow Leopard.
Doty
Look in your Keyboard Shortcuts preference pane in System Preferences. I am guessing that some system preference has globbed that shortcut. You should see a yellow /! next to it in the list somewhere.
Doty
On 3 Apr 2012, at 22:13, Richard Houston wrote:
Here’s another kybd shortcut question: Is there a key modifier that temporarily changes the Arrow Nudge amount from 1px to a larger amount, say 10px?
You can set the arrow nudge to be whatever you like in Preferences. I have mine set to 10px, and if I hold down the Option (Alt) key, it goes to 1px.
best wishes,
Paul Bradforth
Buy my eBooks at:
http://www.paulbradforth.com/books/
goes to 1px.
Very cool – thanks Paul!
Richard
checked all there is to check in system prefs and keyboard shortcuts and no warnings, verrry strange!
Doty
Although it works for me in the Finder and all of my browsers, it
doesn’t work in Freeway. Weird.
R
That is very strange. I don’t have much to add, except to say that I’ve been using this shortcut for as long as I can remember, so I don’t think it was added recently. Several years at least, I believe.
Good Luck,
Doty
Okay, this qualifies as a “duh tip,” but I just remembered it. The command + bracket tips works on history. I just opened a FreeWay document (after having quit the application) and it didn’t work because there was no history. So, click through a few pages and just to make sure, then try it again.
Fingers crossed for you!
Doty
Thanks Doty. I tried this, but no luck. It’s always been a mystery to
me why this sort of strange behavior pops up now and then on computers
in general. Doesn’t make sense.
Richard
I would like to understand why Softpress has never created shortcuts for the tools – the things we change the most, I’d say. To me it’s a cardinal sin.
When I’ve requested it (3-4 times), it seems to go nowhere. They did once say that they have so many shortcuts for other things, any more may be hard to create. I don’t get it. Seems they should have done the tool shortcuts first. Anyone else consider this a problem?
Well, I don’t consider it a problem, but it would be a wonderful and
very useful convenience to have a few more keyboard shortcuts. In my
case, by far the most useful shortcut (switching pages) is already a
part of Freeway, but it only seems to work for some users. Maybe it’s
how the planets line up…
Richard
Maybe it’s how the planets line up…
Or something to do with the FW version you are using?
