Was wondering if there is a way to turn on “kiosk mode” for quicktime movies. It turns “off” the little knob at the bottom right corner and viewers can not download the movie. Thanks for the time!
If you click once on the movie on your page, you can add any number of extended attributes to the movie by using the Item / Extended dialog. Anything you add to the movie itself (not its parent DIV) will be passed along to the JavaScript-generated QuickTime tag when the page is loaded.
