Anyone know where the ‘layer’ checkbox has gone in 5.5 ??
In old 3.5 the Inspector had a clear checkbox to make something a layer. I can’t see any layer function in the Inspector at all now. And there isn’t a layers palette.
Uh oh… I’ve found it now! Don’t know what was going on there. I drew a graphic and positioned it on my design and there was no layer checkbox. I drew another graphic half on and half off the page - i.e. without positioning it) and the layer checkbox was present. Must have been some methodology thing, or maybe combined graphics…?
Disappointingly I can’t see the Layer Positioning action in the default action set (nor in actionsforge) - this let you move layers out of the way to work on other stuff beneath. Not sure how to work with layers now… ?
This starts with an appropriate naming convention for your items - so that they are easily identified.
Then in the Site/Page panel at the LHS (with Show Items enabled) select the item that you wish to work on and use the Enter key to select and open it for editing.
