Hi all,
I’ve recently had to return, for some small amendments/additions, to a site I made in FW 5.5 Pro.
It used some links to trigger layers using the Target Slave Hide/Show action and the Layer Positioning Action.
Slave hide/show works fine but the Layer Positioning no longer positions things anywhere other than off the bottom of the page - i.e. below everything else.
I’m bemused! Only a few months ago I had to make a small addition to the site and everything worked. Now the action has apparently stopped working. No change of OSX environment or anything like that.
I’ve searched on Actions Forge to see if I can replace the layer positioning action but can’t find anything.
Any thoughts? The doc setup/output is HTML 4.01 Transitional, btw.
cheers
Hugh
