I’m not sure what we may discover in your file Trevor – I was having
difficulty just the other day with this inline construction:
http://cssway.thebigerns.com/products/silverscreen/
Everything was fine with it, but if I tried to replace the image of the
columns or my photo at the bottom, the entire inline would collapse. There
was no logical reason for it as no physical dimensions were being changed.
Ultimately I deleted the graphics and their containing html box, made new
ones and after that everything worked just fine. Why? I could never even
begin to speculate.
Nor could I explain why Freeway Pro is always creating duplicate Header
styles every time I turn around, or why it unapplies List styling in the
same inexplicable way.
I don’t know which is worse, that FWP misbehaves this way – or that I’ve
come to accept it as normal.
On Fri, Jul 27, 2012 at 2:58 AM, Trevor Reaveley email@hiddenwrote:
Elizabeth, Ernie, thanks for your replies.
Elizabeth, it sounds like you have the opposite happening to me - my
displacement happens in the Freeway file and not when rendered. I’m pleased
it’s that way, very frustrating otherwise.
Ernie, I’m trying to keep it as uncomplicated as possible and trying to
construct it as inline. This effect happened when I added the large otter
shot as a background image to the right box (so I could get the 3 smaller
insert shots to overlap). Everything was doing nicely before that and
flowing as expected in the working file.
I know this is a lot to ask, but would anyone be prepared to spend 5
minutes just having a look at the FW file, not to rectify it, but to see if
you think I may have overcomplicated things, as Ernie suggests? Or should I
approach Softpress directly?
http://www.trevreav.co.uk/Compare.jpg
