Hi I managed to get split second view, it resizes the animated gif to the size of any image on the page, quite large.
What I did to work around this was to place the animated GIF in Freeway in a much larger box, then filled that box with the background color of the animation. So my box is #cccccc, and the spinner is white, and the spinner is centered neatly on the photo placeholder. Freeway can modify animated GIFs like this without destroying their animation properties. It’s one of the silly tricks I used to use when demonstrating Freeway at Macworld. (Layer a JPEG with an animated GIF, and press Preview – instant merged animated GIF with animation still playing.)
Okay. That makes sense. The effect isn’t firing off because the window
hasn’t scrolled anywhere, which is the event that triggers it. Try
this: change the options block in the last line of the script from
Hi Walter,
OK, test site here: http://concretecreative.co.nz/test/
portfolio.html not working that well with the Carousel. Get a
spinner… also seems to still resize it? Should I make the
preloader larger?
Q: I am thinking of making the gallery a rollover rather than
Carousel though still will; have the same loading issues right?
Please too all cool with doing something different, don’t want to
take up too much of your time,
don’t know you manage to do it all really?
