When in ‘page’ layout (Freeway 5 Pro) I select a change in leading: Style>Leading> 100% to 110% and text looks fine. When changing to ‘view in Safari’ text goes back to 100%? Any suggestions would be appreciated?
In the styles window - I’m not at the computer so can’t remember how to get there - it’s def from the drop downs along the top bar. Then go to para within the text styles
If you click inside the leading field in the Edit Styles dialog, you can enter anything – including units – that you like in there. Try typing 22px as the value (overriding the % sign).
On Jan 15, 2013, at 12:38 PM, John Catchpole wrote:
Hi Justin,
Sorry if I appear to be a bit thick here, but am a novice, how would I change the leading with pixels?
Sometimes too, Freeway Pro doesn’t update the CSS information. In those
cases try a “forced” republish (menu Page > Force Republish) which forces
FWP to regenerate all resources. Then publish and preview in your browser
as normal. Don’t forget to refresh your browser too.
Hi Justin,
