When I have a few pages within a secury directory, how can I define a LOGOUT and a LOGOUT Message?
If you’re using Apache Realm security (user/password set up in your hosting provider’s control panel) then the only way for a person to log out is to quit their browser. The session lasts as long as the browser does. If you are using a cookie-based system (coded in PHP or another scripting language) then you just have to destroy or reset the cookie to log the person out.
Thank you Walt. Do you think that a php based system would be better? There are only a small handfull of users who use these protected pages and there is no register me possibility needed.
Only if there is a security issue with someone logging in once, then never closing their browser and walking away from a public computer.
If you really need time-outs, then you need to use a PHP or other session-based login, where you can control the aging of the cookie.
