Due to other programs that I am using, I have decided to rotate my monitor 90 degrees and I would like Freeway’s pasteboard to be LONGER. I have found the setting in the preferences for width, but no matter if I attempt to drag the window further out toward the bottom, the window stops at midway down my monitor. Any way I can change this preference somewhere ??
And any item that you put at the bottom of your page can be selected as Not to Publish - the published page height will only be as tall as the item farthest down it.
