[Pro] Linking everything
Using freeway 6 how do I Like my photo Galleries to 1 button to view on the web? I tried hyperlink and its not working
I assume that you mean ‘Link my photo…’
How have you created your Galleries? Showcase, Exhibeo or another method.
Normally you would have a Gallery on one of your FW pages and then add a link from your Button to that page by selecting the Button (or Text) Edit>Hyperlink (Cmd + K) and choose your page from the list under the ‘Internal’ Tab in the subsequent dialogue box.
There are other methods too.
I made each page Home, Contacts , Kids , Wedding, etc. I used showcase. now I want to link them to the proper buttons
Or you can use the link picker at the bottom of the FW window.
First select the item you want to create the link from then click on the link picker
And select a page from the list
I tried that and its not linking up
I took a couple of screen shots how do I sent to you so you can see it?
Might help if you watch the Tutorial video at Softpress » Support » Tutorials
Down the page to Introducing Links - for Freeway 4 but the principal is the same.
Note that it has to be a Graphic item or a text selection.
If you click on my name at the head of any of my posts on the FWT website it will take you to my People Page where you will find my email address.
I watch those already and it dosen’t show specificly how to conected the hyperlink
Three steps 1 Select your Button
2 Choose Edit>Hyperlink from the Main menu which will bring up the Edit Hyperlink dialogue box
3 Select the Page you want to link to from the list
4 Click OK
Finished
Ok I drew graphic boxes and wrote the names of my links is that the wrong way?
No - The pictures above are of graphic boxes with text ‘Button’ typed in
Ok how do you make a simple button? so you can link them I read your example but its already done.
How do I send you a screen shot so you can see where I’m at?
In its simplest form:
‘Draw’ a Graphic container using the graphic tool
Click inside it until you get a flashing cursor
Type your text - style it as you like, colour the text and the box.
You can also use the Button action.
Draw a graphic container then with it selected choose Item>Actions>Buttons and set its look in the Action Palette.
Done
As I said earlier this evening: If you click on my name at the head of any of my posts on the FWT website it will take you to my People Page where you will find my email address.
Ok I finally got one of the step. Now I’m trying to link the others and they won’t Link whenI select the hyper link it stays on one page. For example Weddings, Kids, People, in the Gallery button . when I go to hyperlink them. all 3 it won’t take it only wedding Am i missing a step to add all 3 to 1 button?
Ok I guess what what I’m trying to say how do you make a sub folder so I can link all the pages?
Thanks Dave I got. Now Is there a easy way to Line up my buttons to match the inline ment with the other buttons?
1 link per button.
The analogy is a link is like a door to a room.
Each door can only lead to 1 room - you cant go through 1 door and expect to get to 3 different rooms.
Select all the buttons at the same time (shift + click). Use the Menu Item>Align (Cmd + Y)
