I’ve created a left hand list of 5 links (w/rollovers) which
link to PDFs opening in new windows. They were all created the same way–-all set in Trebuchet 14 pt, however the top link in the list somehow changed its “normal” state color to its “visited” state color by mistake.
I reset the link and its colors several times and re-tested in the browser, doing the same thing over and over again. The problem persisted and then finally corrected to the correct “normal” state color.
However, when it corrected its color the font changed from Trebuchet to Times even though the Inspector was set to Trebuchet 14 pt.
I have tried every which way I can to reset and correct.
The problem definitely seems to happen when I asign the action to “open PDF” that’s when the font flips to Times without me setting the Inspector to Times.
I’ve got to find a solution fast, do you know what I
should do to fix this?
file:///*WISNER%20DESIGN/PROJECT%20WIP/2009%20CLIENT%20WORK/FOURTH%20QUARTER/SARA%20LARSON/DR.%20DAHM%20SITE/SITE%20BUILD%201/index.html
Thanks very much,
Patty Wisner
