I’m looking to create a ‘liquid layout’ site, in which the background (image) will re-size to fit the browser window. Sounds simple, however the background image shrinks/enlarges to ALWAYS fit the browser window NO SCROLL BARS).
See example:
Is this possible in FW? I have read past posts and can make my web content re-size to fit the browser window, but not my background?
I have tried makeing it a layered DIV-no luck!
I have used a BG image, set V and H align to centre (this is the closest I have got) but my BG image top is cropped off!!
Like in the example I want my image to always fill the entire background (browser window) and constrain its proportions when re-sized. My graphic image is 1620 W x 1020 H,so when I used this I always automatically get both X/Y scroll bars appear. If you notice in the example these never appear, how do they do that?
Maybe simple, but I’m struggling to get my head around it ATM!
Worm
