I have some complicated sites and sometimes I lose track of where I have put all of my jpegs and pngs and gifs that populate my pages. Is there a way to select an image on a page and tell where the base image is on my computer? Thanks.
Select the graphic from the list and use Edit (bottom right corner)
The next dialogue box that opens will show you a breadcrumb folder trail to your image if you hover over it.
To gather all your originals into one location if you do a Save Archive then FW will put everything together into 1 folder and you can decide where to store/name it.
After you do that and you then edit the FW document that is in the Saved Archive it will only reference the images that are in the Media folder of the Archive.
Don’t see an Edit button. Which List are you referring to? I am looking at the list of images in the left hand column when I go into page mode. Thanks.
