[Pro] Location search
I had this location search created for a customer website in WordPress Can this be done in Freeway?
Thanks John
Possibly. It looks as though it’s just a bunch of JavaScript that is calling out to the Google Maps API, so it should work okay in a Freeway-generated site. You would need to hand-add all those references to the JavaScript and CSS from maps.googleapis.com (last things in the HEAD of the page) using the Page / HTML Markup dialog in Freeway. Then you would need to paste this entire blob of code into the page using a Markup Item where you want it to appear:
Thanks John
Find a Showcase window dealer - Gulf Coast region | Showcase Windows
Walter. Appreciate it.
John
