I’ve a bit of a problem with my WebYep loop and can’t find where the crux of matter lies. In standard and tablet 768px view two loop elements should build a row before the elements continue in the next.
In standard format it works. The loop container’s width is 800px and the left floating loop element (html box with nested WY elements) is 375px wide (both fixed), has a left-margin of 25px and it’s clear is set to „none“
In tablet portrait format, where the loop container is 750px wide and the loop element’s width is 355px with a margin (left) of 15px, floating left, clear „none“, it doesn’t work – I think that it should fit mathematically – the second loop element, which should be in a line with the first, is in the second row. I’ve tried several smaller loop element dimensions, different margin widths, even floating alignments, but nothing helps …
i applied the action to the html-box (loop element) and set the pages width from flexible to fix for the flexible page action. Till now the result is the same. What other steps do I have to do?
Thanks in advance
Ray
