[Pro] Mal-E commerce package "add to cart" buttons
hey everyone,
so i just bought the Mal-E commerce package for Freeway pro 5. I have been running into some problems with it and wondering if anyone on here can answer them.
  1. I want to use “add to cart” graphics, but when I create the button, it doesnt show up on the page itself, what is causing this problem.
  2. when i try to use my own buttons, it will not click. How can i fix that?
I really dont want to use the text buttons, so any help would be greatly appreciated. thanks
actionsdev mailing list
Hi Kevin,
I just replied to you directly with a sample Freeway file but this is what you
need to do.
The action you are looking for is called “Mal’s Buy Image Link”. here’s what to
do;
  1. Add your buy button image to the page as you would normally
  2. Apply the “Mal’s Buy Image Link” action to the image by selecting the Item
    menu, then Actions and finally Mal’s Buy Image Link.
    In the actions palette (Window/Actions) set your store ID and item details such
    as price, description etc.
  3. Publish and test your buy button.
If you are till having problems please feel free to get back to directly.
All the best,
Quoting Keven email@hidden:
hey everyone,
them.
appreciated. thanks
Extend Freeway the way you want with FreewayActions.com
http://www.freewayactions.com
Hi Kevin,
Did you get the ‘add to cart’ using images issue sorted out OK?
Express & Pro.
Spam.
