Maybe an old question, but at the moment what is the best CMS there is to use together with Freeway and Mal’s E-commerce?
Regards, Ronald
Regards, Ronald
See my link below:
http://www.perpetuabloematelier.nl/wwurnenoz.html
have many products in the webshop and many pages.
Must be a more easy way to do this and a way to easy change the products.
hope anyone know a good way
Hi Ronald
this could be done with mals-e and a webyep loop (which is part of the webyep system).
I have an example in the manual and its on page 95 I think!
it basically uses a webyep loop to create new instances of product areas which include a webyep image and a webyep tile WY descriptive text a price ext plus the mals-e-button and all ready for population by the client via a browser.
This is not designed to be used on a massive shopping site but if you have a few items to sell and you need to change the price or the description and occasionally add or remove/hide products then this may be fine for you.
have a read of the manual and see if its enough.
all the best max
http://www.max-izzat.co.uk/Manual-License.zip
Thanks Max, will check your manual now.
Best regards, Ronald
Max, can you maybe give me any examples of webshops you know who used this?
Hi Ronald I don’t know how many people have used this sort of setup although I am sure a webyep users have done it. I have integrated webyep with another cart (roman cart) this was before I had worked out an action which could combine the two.
speak soon max
I remember David Owen did it once (it had to do with glasses, sun-glasses stuff) a set up with mal’s and web yep. This was pretty impressive but am not sure if this still exists.
Maybe if he reads this he can share some wisdom?
