To the wizards of smart;
I am setting up a new cart that combines multi-list/price items, radio or check button and the submit in a table. The table has 7 cells, six to choose from and the seventh - Add to Cart. I have set the 7 cells in the “Form Set Up” action. My first multi-list has 10 items with different pricing’ for each and the the other cells will select color, type, so on and so on. My issue is with the “Buy Now” button. Reading the “Suite’s” manual I have the understanding that the “multi-price/list” action will override the “Buy Now”. button, if the price is different than the “Buy Now” button. However, this is not what is happening. When tested, the price in the shopping cart is the price set up for the button. I have to set a price, in the button, because the action will not along me enter “no price” as an option.
Can anyone help me with this set up? I really need to keep everything lined up as each page can have up to the 30 items per product number.
Is my problem due to having it in a table? If I can’t use the “multi-price/list” action as part of the table and “Buy Now” button I will have to create 4,400 individual items with separate “buy now” buttons. I know there must be a work around.
I uploaded the site so you can see it. The two pages to look at are as follows:
http://www.ergopetdiner.com/gatororder.html
http://www.ergopetdiner.com/uflorder.html
The second page; /uflorder.html was the first page I built and I actually like the look, however, I would have to build over two hundred pages with over 4,400 products - to cover all the teams in the NCAA, NHL, NFL so on and so on.
The first page was my thought to shorten the building time frame, to cover all that I need to cover.
Both pages act the same way. None of the multi-price/list that are selected or clicked on the check boxes show up in the shopping cart. Basically it sees only the submit button. The first page uses tables and the second uses the HTML box. Both have the “Form Setup” action applied.
Does having the Carousel and Newscycle actions have anything to do with it?
I hope this give you more to go on.
David Hamill, Black Creek / Ergo Pet Diner
